Einleitung
Using this guide you will be able to replace or remove the RAM from your laptop.
Was du brauchst
Flip your laptop over so the back panel is facing upwards.
Locate the lock switch below the battery.
Slide the lock switch to the right using your finger or a spudger.
At the same time, grasp the battery with your other hand and slide it out of the laptop.
Remove the battery.
Unscrew the one 2.5 x 8mm Phillips #0 screw from the bottom panel as designated in the image.
Remove the back panel by carefully disengaging it around the edges and then pull upwards.
Disengage the metal tabs located on either side of the RAM stick by pulling the tabs outward.
Carefully remove the RAM so you don't damage the connectors.
Eine weitere Person hat diese Anleitung absolviert.
