Zum Hauptinhalt wechseln
ACER Aspire V5-571P-6609 RAM Replacement
Was du brauchst
  1. ACER Aspire V5-571P-6609 RAM Replacement, RAM: Schritt 1, Bild 1 von 3 ACER Aspire V5-571P-6609 RAM Replacement, RAM: Schritt 1, Bild 2 von 3 ACER Aspire V5-571P-6609 RAM Replacement, RAM: Schritt 1, Bild 3 von 3
    • Make sure you completely power off the device before proceeding.
    • Turn over the device to display the back cover and remove the two marked Phillips #0 screws.
  2. ACER Aspire V5-571P-6609 RAM Replacement: Schritt 2, Bild 1 von 3 ACER Aspire V5-571P-6609 RAM Replacement: Schritt 2, Bild 2 von 3 ACER Aspire V5-571P-6609 RAM Replacement: Schritt 2, Bild 3 von 3
    • Once the screws have been removed, utilize a jimmy tool to pry open the back cover. Carefully lift the cover and set it aside for now.
  3. ACER Aspire V5-571P-6609 RAM Replacement: Schritt 3, Bild 1 von 3 ACER Aspire V5-571P-6609 RAM Replacement: Schritt 3, Bild 2 von 3 ACER Aspire V5-571P-6609 RAM Replacement: Schritt 3, Bild 3 von 3
    • With two fingers, push the latches holding the DIMM to the sides.
    • The DIMM will tilt upward once it is released from the slot.
    • Carefully secure the DIMM and remove it.
  4. ACER Aspire V5-571P-6609 RAM Replacement: Schritt 4, Bild 1 von 3 ACER Aspire V5-571P-6609 RAM Replacement: Schritt 4, Bild 2 von 3 ACER Aspire V5-571P-6609 RAM Replacement: Schritt 4, Bild 3 von 3
    • Repeat the same process from the previous step for the second slot.
  5. ACER Aspire V5-571P-6609 RAM Replacement: Schritt 5, Bild 1 von 2 ACER Aspire V5-571P-6609 RAM Replacement: Schritt 5, Bild 2 von 2
    • Insert the replacement DIMM into the slot.
    • Once inserted, push the DIMM down gently until it snaps into place.
  6. ACER Aspire V5-571P-6609 RAM Replacement: Schritt 6, Bild 1 von 3 ACER Aspire V5-571P-6609 RAM Replacement: Schritt 6, Bild 2 von 3 ACER Aspire V5-571P-6609 RAM Replacement: Schritt 6, Bild 3 von 3
    • Place the cover back on.
    • Insert the screws back into place with a screwdriver.
Abschluss
To reassemble your device, follow these instructions in reverse order with new RAM cards.
Ernesto Pacheco
277 Reputation
2 Anleitungen geschrieben
Gateway, Team 1-1, Pee Fall 2022 Mitglied von Gateway, Team 1-1, Pee Fall 2022
GCC-PEE-F22S1G1
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 185
