Zum Hauptinhalt wechseln
ACN Iris WG4K Lower Case Replacement
Was du brauchst
  1. ACN Iris WG4K Lower Case Replacement, Handset: Schritt 1, Bild 1 von 2 ACN Iris WG4K Lower Case Replacement, Handset: Schritt 1, Bild 2 von 2
    • Press upwards with your index finger on the 4P4C connector as shown in the image.
    • Pull the connector gently out of its socket.
  2. ACN Iris WG4K Lower Case Replacement, Lower Case: Schritt 2, Bild 1 von 1
    • Flip the main body of the video phone so that the bottom is facing up.
    • Use the Phillips #0 Screwdriver to remove the four Phillips head screws (6 mm) highlighted by the red circles.
  3. ACN Iris WG4K Lower Case Replacement: Schritt 3, Bild 1 von 2 ACN Iris WG4K Lower Case Replacement: Schritt 3, Bild 2 von 2
    • Lift the back case upwards to expose the inside components.
    • Red rectangles indicate the three ribbon cables.
    • The orange square indicates the blade connector.
  4. ACN Iris WG4K Lower Case Replacement: Schritt 4, Bild 1 von 3 ACN Iris WG4K Lower Case Replacement: Schritt 4, Bild 2 von 3 ACN Iris WG4K Lower Case Replacement: Schritt 4, Bild 3 von 3
    • Disconnect the three ribbon cables from their insulation-displacement connectors by flipping up the black plastic clip.
    • Gently pull the ribbon cables out of their insulation-displacement connectors.
  5. ACN Iris WG4K Lower Case Replacement: Schritt 5, Bild 1 von 2 ACN Iris WG4K Lower Case Replacement: Schritt 5, Bild 2 von 2
    • Disconnect the blade connector from the blade receptacle by gripping the exposed area of the blade connector.
    • Gently pull the blade connector out of the blade receptacle.
  6. ACN Iris WG4K Lower Case Replacement: Schritt 6, Bild 1 von 1
    • Gently lift up the lower case to separate it from the top case.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Itze Kenney
1.066 Reputation
9 Anleitungen geschrieben
USF Tampa, Team 20-4, Remmell Spring 2017 Mitglied von USF Tampa, Team 20-4, Remmell Spring 2017
USFT-REMMELL-S17S20G4
4 Mitglieder
20 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 9
Insgesamt: 191
