Zum Hauptinhalt wechseln
AEE Mach 1 Camera Replacement
Was du brauchst
  1. AEE Mach 1 Camera Replacement, Camera: Schritt 1, Bild 1 von 1
    • Take out the AEE Mach 1 and place it on a surface with its propellers facing up.
  2. AEE Mach 1 Camera Replacement: Schritt 2, Bild 1 von 2 AEE Mach 1 Camera Replacement: Schritt 2, Bild 2 von 2
    • Holding the base of a propeller with one hand, unscrew the propeller by hand in a clockwise direction. Complete this action on all 4 propellers.
  3. AEE Mach 1 Camera Replacement: Schritt 3, Bild 1 von 2 AEE Mach 1 Camera Replacement: Schritt 3, Bild 2 von 2
    • Flip the AEE Mach 1 upside down.
    • Remove the screws on the drone's arms using a Torx T5 screwdriver.
  4. AEE Mach 1 Camera Replacement: Schritt 4, Bild 1 von 2 AEE Mach 1 Camera Replacement: Schritt 4, Bild 2 von 2
    • Gently pry open the top panel of the drone using a spudger.
    • Do not completely remove the panel, as there will still be wired connections between the two halves.
    • Rotate the top panel slightly to reveal the four screws beneath each propellor arm.
    • Remove each of the four screws with a Phillips #0 screwdriver.
    • Lift off the top panel, as it should now be free from the rest of the device.
  5. AEE Mach 1 Camera Replacement: Schritt 5, Bild 1 von 1
    • Using a Phillips #00 screwdriver, remove the screws from the four corners of the inner white chassis.
  6. AEE Mach 1 Camera Replacement: Schritt 6, Bild 1 von 2 AEE Mach 1 Camera Replacement: Schritt 6, Bild 2 von 2
    • Using a Spudger (or similar tool to scrap/pry with), remove the copper foil used as tape from the sides of the chassis.
    • Remove the small metal covering from the side boards.
    • This can be done by hand or with the assistance of a prying tool.
  7. AEE Mach 1 Camera Replacement: Schritt 7, Bild 1 von 2 AEE Mach 1 Camera Replacement: Schritt 7, Bild 2 von 2
    • Using a Phillips #00 screwdriver, remove the four screws separating the side board from the white chassis.
  8. AEE Mach 1 Camera Replacement: Schritt 8, Bild 1 von 2 AEE Mach 1 Camera Replacement: Schritt 8, Bild 2 von 2
    • Using a Phillips #00 screwdriver, remove the four screws from the large motherboard on the white chassis.
    • Lift the motherboard out of the case, revealing the camera cable.
  9. AEE Mach 1 Camera Replacement: Schritt 9, Bild 1 von 3 AEE Mach 1 Camera Replacement: Schritt 9, Bild 2 von 3 AEE Mach 1 Camera Replacement: Schritt 9, Bild 3 von 3
    • Using the Phillips #00 screwdriver, remove the four screws holding the camera mechanism in place.
    • Lift the camera assembly out of the case.
Abschluss
dwsad Mitglied von dwsad
Community
1 Mitglied
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 16
Insgesamt: 268
