Einleitung
I created this guide after successfully trying this with our oven which started turning itself off after overheating caused by inactivity of the top fan. It is working again like before now. The replacement part was about 20$ on eBay.
Was du brauchst
Remove both screws that are used to hold the oven in place
Cautiously pull out the oven and place it on a small table. Be prepared for medium weight and use the handles in the middle of the oven on both sides.
Remove the two screws,
now slide the top metal sheet to the rear end of the oven
until you are able to lift the front edge of it and remove it entirely.
Cautiously pull out the ends of both white cables
Also pull out the light blue ones
This is the switch, hidden in cables
Now put in the new switch and pay attention that it doesn't touch any metal surfaces that may get hot
To reassemble your device, follow these instructions in reverse order
2 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Bjarne hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
