Zum Hauptinhalt wechseln
AKASO KingPad A90 Rear Speaker Replacement
Was du brauchst
  1. AKASO KingPad A90 Rear Speaker Replacement, Rear Speaker: Schritt 1, Bild 1 von 3 AKASO KingPad A90 Rear Speaker Replacement, Rear Speaker: Schritt 1, Bild 2 von 3 AKASO KingPad A90 Rear Speaker Replacement, Rear Speaker: Schritt 1, Bild 3 von 3
    • Remove screws.
    • Insert spudger tool on the middle of the left side, between the white and black plastic.
    • Slide in a plastic opening tool and use it to further pull the back off.
    • Work your way around the edge of the tablet with the plastic opening tool and insert more as needed.
    • Pull off the back cover.
  2. AKASO KingPad A90 Rear Speaker Replacement: Schritt 2, Bild 1 von 3 AKASO KingPad A90 Rear Speaker Replacement: Schritt 2, Bild 2 von 3 AKASO KingPad A90 Rear Speaker Replacement: Schritt 2, Bild 3 von 3
    • Plug in soldering iron and let it warm up for ten minutes.
    • Locate the speaker solder points and note where it is attached to the motherboard.
    • Solder the old speaker out of its mark. (Touch the tip of the solder iron to the soldering point).
  3. AKASO KingPad A90 Rear Speaker Replacement: Schritt 3, Bild 1 von 3 AKASO KingPad A90 Rear Speaker Replacement: Schritt 3, Bild 2 von 3 AKASO KingPad A90 Rear Speaker Replacement: Schritt 3, Bild 3 von 3
    • Solder the new speaker onto the points where the old speaker was.
  4. AKASO KingPad A90 Rear Speaker Replacement: Schritt 4, Bild 1 von 3 AKASO KingPad A90 Rear Speaker Replacement: Schritt 4, Bild 2 von 3 AKASO KingPad A90 Rear Speaker Replacement: Schritt 4, Bild 3 von 3
    • Replace the back cover with the new rear speaker unit in place.
    • Gently press the speaker into place.
    • Don't let the volume rocker unit fall out of place.
    • Replace the screws.
Ziellinie
camchristo
71 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team 4-6, Vijaybhaskar Spring 2015 Mitglied von UMass Dartmouth, Team 4-6, Vijaybhaskar Spring 2015
UMASSD-VIJAYBHASKAR-S15S4G6
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 380
