Zum Hauptinhalt wechseln
APEX AP-GS918 Power/Volume Button Replacement
Was du brauchst
  1. APEX AP-GS918 Power/Volume Button Replacement, Power/Volume Button: Schritt 1, Bild 1 von 3 APEX AP-GS918 Power/Volume Button Replacement, Power/Volume Button: Schritt 1, Bild 2 von 3 APEX AP-GS918 Power/Volume Button Replacement, Power/Volume Button: Schritt 1, Bild 3 von 3
    • To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
  2. APEX AP-GS918 Power/Volume Button Replacement: Schritt 2, Bild 1 von 3 APEX AP-GS918 Power/Volume Button Replacement: Schritt 2, Bild 2 von 3 APEX AP-GS918 Power/Volume Button Replacement: Schritt 2, Bild 3 von 3
    • Squeeze the plastic opening tool in between the seam where the screen joins the plastic case.
    • Begin separating the bottom of the case from the screen by carefully going around the whole edge of the case and slowly prying it apart.
    • Be careful when separating the lids because the wires holding the speaker to the motherboard are very short.
  3. APEX AP-GS918 Power/Volume Button Replacement: Schritt 3, Bild 1 von 2 APEX AP-GS918 Power/Volume Button Replacement: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Carefully place the bottom lid next to the screen case. The power/speaker buttons should be visible at the corner of the lid. Remove the buttons with the tweezers.
Abschluss
USF Tampa, Team 9-1, Leahy Winter 2015 Mitglied von USF Tampa, Team 9-1, Leahy Winter 2015
USFT-LEAHY-W15S9G1
3 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 226
