Einleitung
This repair guide will take you through the steps to removing and replacing the channel switch of your APS Tech 101629 CD-Drive. This can be quickly removed and easily replaced.
First the external casing will need to be removed.
Ersatzteile
Kein Ersatzteil erforderlich.
Pry 4 plastic feet off the bottom of the enclosure using the iPod opening tool.
Flip the device right side up, then gently slide the casing upwards and off the hard drive.
Flip device upside down again.
Gently pry the bottom gray casing away from the device.
Rotate so back of device is facing you, then gently pry the back casing away.
When back casing is removed, the fan will become loose.
Find the conjoined ID cable wires that are colored black, orange, and yellow, and disconnect it from the white portion.
Using the spudger, depress the pressure holders at all four corners of the fan.
Take out the fan and its cords, by pulling it outward from its cavity within the device.
Ein weiterer Nutzer hat diese Anleitung absolviert.
