Zum Hauptinhalt wechseln
APS Tech 101629 Internal Drive Component Replacement
Was du brauchst
  1. APS Tech 101629 Internal Drive Component Replacement, External Casing: Schritt 1, Bild 1 von 3 APS Tech 101629 Internal Drive Component Replacement, External Casing: Schritt 1, Bild 2 von 3 APS Tech 101629 Internal Drive Component Replacement, External Casing: Schritt 1, Bild 3 von 3
    • Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
  2. APS Tech 101629 Internal Drive Component Replacement: Schritt 2, Bild 1 von 2 APS Tech 101629 Internal Drive Component Replacement: Schritt 2, Bild 2 von 2
    • Unscrew the four screws previously covered by the feet with a Phillips #1 screwdriver.
  3. APS Tech 101629 Internal Drive Component Replacement: Schritt 3, Bild 1 von 2 APS Tech 101629 Internal Drive Component Replacement: Schritt 3, Bild 2 von 2
    • Flip the device right side up.
    • Gently slide the casing upwards and off the hard drive.
  4. APS Tech 101629 Internal Drive Component Replacement: Schritt 4, Bild 1 von 1
    • Flip device upside down again.
    • Gently pry the bottom gray casing away from the device.
  5. APS Tech 101629 Internal Drive Component Replacement: Schritt 5, Bild 1 von 2 APS Tech 101629 Internal Drive Component Replacement: Schritt 5, Bild 2 von 2
    • Rotate so the back of the device is facing you.
    • Gently pry the back casing away.
    • When the back casing is removed, the fan will become loose.
  6. APS Tech 101629 Internal Drive Component Replacement, Internal Drive Component: Schritt 6, Bild 1 von 2 APS Tech 101629 Internal Drive Component Replacement, Internal Drive Component: Schritt 6, Bild 2 von 2
    • Flip so device is upside down.
    • Remove 4 screws with Phillips #1 screw driver.
    • Be sure to save the washers that seperate the screws from the baseplate for reassembly.
  7. APS Tech 101629 Internal Drive Component Replacement: Schritt 7, Bild 1 von 2 APS Tech 101629 Internal Drive Component Replacement: Schritt 7, Bild 2 von 2
    • Slide the internal drive component away from the back of the device.
    • Remove the connections from the back of the internal component in the order of your choosing, we suggest left to right. The connections are:
    • Audio Connection
    • SCSI ID
    • Terminate On
    • SCSI Connection
    • DC Input (power)
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Alexis Weckel
140 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 24-60, Amido Spring 2011 Mitglied von Cal Poly, Team 24-60, Amido Spring 2011
CPSU-AMIDO-S11S24G60
5 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 1,080
