Zum Hauptinhalt wechseln
ASDA ES177 Steam Iron Power cord Replacement
Was du brauchst
  1. ASDA ES177 Steam Iron Power cord Replacement, Disassembly: Schritt 1, Bild 1 von 3 ASDA ES177 Steam Iron Power cord Replacement, Disassembly: Schritt 1, Bild 2 von 3 ASDA ES177 Steam Iron Power cord Replacement, Disassembly: Schritt 1, Bild 3 von 3
    • Remove the security screw from the back panel.
    • Be cautious of any residual charge when disassembling.
  2. ASDA ES177 Steam Iron Power cord Replacement, Remove the back plate: Schritt 2, Bild 1 von 3 ASDA ES177 Steam Iron Power cord Replacement, Remove the back plate: Schritt 2, Bild 2 von 3 ASDA ES177 Steam Iron Power cord Replacement, Remove the back plate: Schritt 2, Bild 3 von 3
    • Insert a flathead screwdriver to pop off the back plate
  3. ASDA ES177 Steam Iron Power cord Replacement, Remove the cord from the holder: Schritt 3, Bild 1 von 3 ASDA ES177 Steam Iron Power cord Replacement, Remove the cord from the holder: Schritt 3, Bild 2 von 3 ASDA ES177 Steam Iron Power cord Replacement, Remove the cord from the holder: Schritt 3, Bild 3 von 3
    • Remove the retainer clamp by unscrewing the two Phillips screws.
  4. ASDA ES177 Steam Iron Power cord Replacement, Release the cord from the connector: Schritt 4, Bild 1 von 3 ASDA ES177 Steam Iron Power cord Replacement, Release the cord from the connector: Schritt 4, Bild 2 von 3 ASDA ES177 Steam Iron Power cord Replacement, Release the cord from the connector: Schritt 4, Bild 3 von 3
    • Remove the three flat-headed screws from the connector
  5. ASDA ES177 Steam Iron Power cord Replacement, Remove the plug: Schritt 5, Bild 1 von 3 ASDA ES177 Steam Iron Power cord Replacement, Remove the plug: Schritt 5, Bild 2 von 3 ASDA ES177 Steam Iron Power cord Replacement, Remove the plug: Schritt 5, Bild 3 von 3
    • Unscrew the main screw to reveal the 3-core cable.
    • Remove the two screws that retain the cord in the plug.
  6. ASDA ES177 Steam Iron Power cord Replacement, Remove the rotator support: Schritt 6, Bild 1 von 1
    • Remove the rotator guide.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
honakrisi
3.718 Reputation
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 980
