Zum Hauptinhalt wechseln
ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement
Was du brauchst
  1. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement, Lower Case: Schritt 1, Bild 1 von 1
    • Use the T5 screwdriver to remove the nine 2.1 mm screws from the bottom of the device.
  2. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: Schritt 2, Bild 1 von 1
    • Use the iFixit opening tool to remove the 4 pads to reveal six 3.1 mm screws underneath.
  3. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: Schritt 3, Bild 1 von 1
    • Use the T5 screwdriver to remove the six 3.1 mm screws under the pads.
    • There might be a layer of tape that covers the screws. Remove the tape first with a pair of tweezers.
  4. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: Schritt 4, Bild 1 von 1
    • Use the iFixit opening tool to remove the back of the laptop.
  5. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: Schritt 5, Bild 1 von 1
    • Use the blunt nose tweezers to separate the keyboard from the internal components.
  6. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement, Trackpad: Schritt 6, Bild 1 von 2 ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement, Trackpad: Schritt 6, Bild 2 von 2
    • Grip the keyboard and carefully pull it off the device.
  7. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: Schritt 7, Bild 1 von 2 ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: Schritt 7, Bild 2 von 2
    • On the back of the keyboard assembly, use the tweezers to pull the white cable from the track pad.
  8. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: Schritt 8, Bild 1 von 1
    • Remove the three 1 mm screws from the track pad using the JIS 00 screwdriver.
  9. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: Schritt 9, Bild 1 von 2 ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: Schritt 9, Bild 2 von 2
    • Grip the track pad with the tweezers and slide it up and out of the keyboard assembly.
Abschluss
Lauren Schirle
205 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S19-G4, White Winter 2019 Mitglied von Cal Poly, Team S19-G4, White Winter 2019
CPSU-WHITE-W19S19G4
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 338
