Einleitung
Details to remove the volume control of ASUS Chromebook Flip C100PA-RBRKT07
Was du brauchst
Use the T5 screwdriver to remove the nine 2.1 mm screws from the bottom of the device.
Use the iFixit opening tool to remove the 4 pads to reveal six 3.1 mm screws underneath.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use the T5 screwdriver to remove the six 3.1 mm screws under the pads.
Use the blunt nose tweezers to separate the keyboard from the internal components.
Use the tweezers to remove the white cable from the volume control component.
