Zum Hauptinhalt wechseln
ASUS Chromebook C200MA DS01 Touchpad Replacement
Was du brauchst
  1. ASUS Chromebook C200MA DS01 Touchpad Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Before proceeding, power down your Chromebook. Close the display and lay it on a soft surface, top-side down.
    • Remove the five 8.4 mm Phillips #0 screws.
    • Remove the four 4.6 mm Phillips #0 screws.
  2. ASUS Chromebook C200MA DS01 Touchpad Replacement: Schritt 2, Bild 1 von 1
    • Use the plastic opening tool to gently work around the edge of the Chromebook until the back panel starts to lift off.
  3. ASUS Chromebook C200MA DS01 Touchpad Replacement: Schritt 3, Bild 1 von 1
    • Remove the back panel by lifting it away from the Chromebook.
    • Some clicking will be heard as the panel is removed from the back, this is completely normal.
  4. ASUS Chromebook C200MA DS01 Touchpad Replacement, Battery Connection: Schritt 4, Bild 1 von 3 ASUS Chromebook C200MA DS01 Touchpad Replacement, Battery Connection: Schritt 4, Bild 2 von 3 ASUS Chromebook C200MA DS01 Touchpad Replacement, Battery Connection: Schritt 4, Bild 3 von 3
    • To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
  5. ASUS Chromebook C200MA DS01 Touchpad Replacement, Battery: Schritt 5, Bild 1 von 2 ASUS Chromebook C200MA DS01 Touchpad Replacement, Battery: Schritt 5, Bild 2 von 2
    • Remove the four 4.7 mm Phillips #0 screws that secure the battery to the Chromebook.
  6. ASUS Chromebook C200MA DS01 Touchpad Replacement: Schritt 6, Bild 1 von 1
    • Pull out the battery.
  7. ASUS Chromebook C200MA DS01 Touchpad Replacement, Touchpad: Schritt 7, Bild 1 von 1
    • Locate the touchpad.
    • Locate the touch pad cable connector.
  8. ASUS Chromebook C200MA DS01 Touchpad Replacement: Schritt 8, Bild 1 von 3 ASUS Chromebook C200MA DS01 Touchpad Replacement: Schritt 8, Bild 2 von 3 ASUS Chromebook C200MA DS01 Touchpad Replacement: Schritt 8, Bild 3 von 3
    • Disconnect the touch pad ZIF(zero insertion force) connector.
    • Flip the flap up using a spudger or your fingers.
    • Pull gently on the ribbon cable to disconnect.
  9. ASUS Chromebook C200MA DS01 Touchpad Replacement: Schritt 9, Bild 1 von 1
    • Gently remove the adhesive on the touch pad ribbon cable.
  10. ASUS Chromebook C200MA DS01 Touchpad Replacement: Schritt 10, Bild 1 von 3 ASUS Chromebook C200MA DS01 Touchpad Replacement: Schritt 10, Bild 2 von 3 ASUS Chromebook C200MA DS01 Touchpad Replacement: Schritt 10, Bild 3 von 3
    • Gently remove the metallic tape from the touch pad only.
    • Try not to tear the tape, it can be re-used during reassembly.
  11. ASUS Chromebook C200MA DS01 Touchpad Replacement: Schritt 11, Bild 1 von 1
    • Remove the three 1.8 mm Phillips #00 screws.
  12. ASUS Chromebook C200MA DS01 Touchpad Replacement: Schritt 12, Bild 1 von 2 ASUS Chromebook C200MA DS01 Touchpad Replacement: Schritt 12, Bild 2 von 2
    • Lift the far edge of the touch pad to remove it.
Abschluss
Cal Poly, Team S23-G4, Livingston Spring 2017 Mitglied von Cal Poly, Team S23-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G4
4 Mitglieder
19 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 5
Insgesamt: 587
