Zum Hauptinhalt wechseln
ASUS Chromebook C200MA DS01 USB Board Replacement
Was du brauchst
  1. ASUS Chromebook C200MA DS01 USB Board Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Before proceeding, power down your Chromebook. Close the display and lay it on a soft surface, top-side down.
    • Remove the five 8.4 mm Phillips #0 screws.
    • Remove the four 4.6 mm Phillips #0 screws.
  2. ASUS Chromebook C200MA DS01 USB Board Replacement: Schritt 2, Bild 1 von 1
    • Use the plastic opening tool to gently work around the edge of the Chromebook until the back panel starts to lift off.
  3. ASUS Chromebook C200MA DS01 USB Board Replacement: Schritt 3, Bild 1 von 1
    • Remove the back panel by lifting it away from the Chromebook.
    • Some clicking will be heard as the panel is removed from the back, this is completely normal.
  4. ASUS Chromebook C200MA DS01 USB Board Replacement, Battery Connection: Schritt 4, Bild 1 von 3 ASUS Chromebook C200MA DS01 USB Board Replacement, Battery Connection: Schritt 4, Bild 2 von 3 ASUS Chromebook C200MA DS01 USB Board Replacement, Battery Connection: Schritt 4, Bild 3 von 3
    • To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
  5. ASUS Chromebook C200MA DS01 USB Board Replacement, USB Board: Schritt 5, Bild 1 von 3 ASUS Chromebook C200MA DS01 USB Board Replacement, USB Board: Schritt 5, Bild 2 von 3 ASUS Chromebook C200MA DS01 USB Board Replacement, USB Board: Schritt 5, Bild 3 von 3
    • Disconnect the USB board ZIF (zero insertion force) connectors which connect the motherboard to the USB board in the upper left.
    • Flip the ZIF retaining flaps up using a plastic opening tool or your fingers.
    • Pull gently on the ribbon cable to disconnect it from the sockets.
  6. ASUS Chromebook C200MA DS01 USB Board Replacement: Schritt 6, Bild 1 von 1
    • Remove the three 5.77 mm Phillips screws on the USB board.
    • Remove the two 4.77 mm Phillips screws from the hinge.
  7. ASUS Chromebook C200MA DS01 USB Board Replacement: Schritt 7, Bild 1 von 1
    • Use a plastic opening tool to lift the hinge from the Chromebook.
  8. ASUS Chromebook C200MA DS01 USB Board Replacement: Schritt 8, Bild 1 von 1
    • Gently lift the USB board from the Chromebook.
Abschluss
Cal Poly, Team S23-G4, Livingston Spring 2017 Mitglied von Cal Poly, Team S23-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G4
4 Mitglieder
19 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 538
