Einleitung
This guide will take you through a step-by-step process for the removal of your Chromebook’s wireless card.
Was du brauchst
Remove the five 8.4 mm Phillips #0 screws.
Remove the four 4.6 mm Phillips #0 screws.
Use the plastic opening tool to gently work around the edge of the Chromebook until the back panel starts to lift off.
To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
Remove the silver 2.8 mm Phillips #0 screw from the wireless card.
Use a spudger to disconnect the white and black antenna cables connected to the wireless card.
Grab the wireless card between your thumb and index finger and pull directly away from the motherboard.
