Einleitung
This guide will take you through a step-by-step process for the removal of your Chromebook’s screen.
Was du brauchst
Remove the five 8.4 mm Phillips #0 screws.
Remove the four 4.6 mm Phillips #0 screws.
Use the plastic opening tool to gently work around the edge of the Chromebook until the back panel starts to lift off.
To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
Disconnect the screen cable connector located on the top right of the motherboard.
Using a spudger, gently pry up the sides of the connector.
Pull the connector off with your fingers.
Disconnect the black and white antenna cable connectors for the WiFi card. The connectors look like small buttons on the ends of colored wires.
Gently pry the cable connectors off with your fingers or a spudger.
Peel the back the black piece of tape holding the connectors in place
Remove the three 5.7 mm #0 Phillips screws in the left hinge mount.
Remove the two 5.7 mm #0 Phillips screws in the right hinge mount.
Pry up the bigger hinge on the top left of the Chromebook with a plastic spudger.
With your fingers, bend the hinge all the way back until it is perpendicular to the Chromebook.
Repeat this process on the smaller hinge on the top right.
Grab the sides of the Chromebook as if you were opening it.
Slowly hinge the back of the Chromebook away from the screen.
Use your middle fingers to push the back of the Chromebook towards you, and away from the hinges. At this point the keyboard and the screen should be completely seperated
Using the plastic prying tool, pry open the outer non-hinge edges of the screen frame by sliding the tool around the perimeter of the frame.
Work two fingers under the inside edge of the plastic screen cover then slide them across the screen, unhooking all the connections.
Remove the four 2.8 mm #00 Phillips screws located around the perimeter of the screen.
Peel the tape that holds the cable connector in place and slide the connector out.
