Zum Hauptinhalt wechseln
ASUS Chromebook C300MA-DH01 Audio Speakers Replacement
Was du brauchst
  1. ASUS Chromebook C300MA-DH01 Audio Speakers Replacement, Audio Speakers: Schritt 1, Bild 1 von 1
    • Flip the Chromebook over so the bottom of the device is facing up.
  2. ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: Schritt 2, Bild 1 von 2 ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: Schritt 2, Bild 2 von 2
    • Using the JIS-J0 Screwdriver, remove the following screws from the bottom:
    • (5) Five 6mm screws
    • (6) Six 8mm screws
  3. ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: Schritt 3, Bild 1 von 3 ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: Schritt 3, Bild 2 von 3 ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: Schritt 3, Bild 3 von 3
    • Gently wedge the spudger in between the bottom of the device and the keyboard, and carefully pry the cover open. Then, carefully lift up on keyboard.
  4. ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: Schritt 4, Bild 1 von 3 ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: Schritt 4, Bild 2 von 3 ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: Schritt 4, Bild 3 von 3
    • Gently detach connecting cables
    • Carefully flip up the large black tab.
    • Carefully flip up the small white tab.
    • Remove its corresponding black cable.
    • Remove the corresponding white cable.
    • The keyboard will be fully detached at this point.
  5. ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: Schritt 5, Bild 1 von 2 ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: Schritt 5, Bild 2 von 2
    • Using the JIS-J0 screwdriver, unscrew and remove from the battery:
    • (6) Six 6mm screws
  6. ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: Schritt 6, Bild 1 von 1
    • Using the plastic opening tool, gently push the connector tab away from the battery to detach the cable.
    • The battery will be fully detached at this point. Carefully lift it out of the device.
  7. ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: Schritt 7, Bild 1 von 2 ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: Schritt 7, Bild 2 von 2
    • Using the plastic opening tool, disconnect the audio connector by pushing the audio tab toward the speakers.
    • With the audio cable detached, carefully lift the speakers out of the device.
Abschluss
Gina Altimari
401 Reputation
4 Anleitungen geschrieben
USF Tampa, Team S2-G5, Passmore Fall 2017 Mitglied von USF Tampa, Team S2-G5, Passmore Fall 2017
USFT-PASSMORE-F17S2G5
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 123
