Einleitung
Use this guide to remove the audio speakers in your device.
Was du brauchst
Flip the Chromebook over so the bottom of the device is facing up.
Using the JIS-J0 Screwdriver, remove the following screws from the bottom:
(5) Five 6mm screws
(6) Six 8mm screws
Gently wedge the spudger in between the bottom of the device and the keyboard, and carefully pry the cover open. Then, carefully lift up on keyboard.
Carefully flip up the large black tab.
Carefully flip up the small white tab.
Remove its corresponding black cable.
Remove the corresponding white cable.
Using the JIS-J0 screwdriver, unscrew and remove from the battery:
(6) Six 6mm screws
Using the plastic opening tool, gently push the connector tab away from the battery to detach the cable.
Using the plastic opening tool, disconnect the audio connector by pushing the audio tab toward the speakers.
With the audio cable detached, carefully lift the speakers out of the device.
