Zum Hauptinhalt wechseln
ASUS Chromebook C424MA-DH48F Battery Replacement
Was du brauchst
  1. ASUS Chromebook C424MA-DH48F Battery Replacement, Lower Case: Schritt 1, Bild 1 von 2 ASUS Chromebook C424MA-DH48F Battery Replacement, Lower Case: Schritt 1, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the eleven 6.9 mm screws that secure the lower case.
    • Make sure all the screws on this side get taken out because there could be a label or warranty sticker covering up a screw that might be missed.
    • Insert an opening pick into the gap between the lower case and chassis.
    • Slide the pick around the entire perimeter of the laptop until the lower case fully releases.
    • Remove the lower case.
  2. ASUS Chromebook C424MA-DH48F Battery Replacement, ASUS Chromebook C424MA-DH48F Battery Disconnection: Schritt 2, Bild 1 von 3 ASUS Chromebook C424MA-DH48F Battery Replacement, ASUS Chromebook C424MA-DH48F Battery Disconnection: Schritt 2, Bild 2 von 3 ASUS Chromebook C424MA-DH48F Battery Replacement, ASUS Chromebook C424MA-DH48F Battery Disconnection: Schritt 2, Bild 3 von 3
    • Use an opening tool to pop up the silver locking bar securing the battery connector.
    • Push the battery connector directly out of its motherboard port.
  3. ASUS Chromebook C424MA-DH48F Battery Replacement, Battery: Schritt 3, Bild 1 von 3 ASUS Chromebook C424MA-DH48F Battery Replacement, Battery: Schritt 3, Bild 2 von 3 ASUS Chromebook C424MA-DH48F Battery Replacement, Battery: Schritt 3, Bild 3 von 3
    • Carefully use the plastic prying tool and pop up the locking bar and lift the connector off with your hand.
  4. ASUS Chromebook C424MA-DH48F Battery Replacement: Schritt 4, Bild 1 von 3 ASUS Chromebook C424MA-DH48F Battery Replacement: Schritt 4, Bild 2 von 3 ASUS Chromebook C424MA-DH48F Battery Replacement: Schritt 4, Bild 3 von 3
    • Use a Phillips #0 screwdriver to remove the six 4.1 mm screws that secure the battery.
    • The two screw holes (marked in orange) on the bottom won't have screws associated with them since they were removed earlier when the base was removed.
    • Unseat the speaker cable from the black plastic hooks on the lower side of the battery.
    • Lift the battery up and out of the chassis.
Abschluss
For optimal performance, after completing this guide, calibrate your newly installed battery.
Eine weitere Person hat diese Anleitung absolviert.
Anthony Wink
425 Reputation
3 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 15
Insgesamt: 238
