Einleitung
Use this guide to replace the lower case on an ASUS Chromebook C424MA-DH48F.
Was du brauchst
Use a Phillips #0 screwdriver to remove the eleven 6.9 mm screws that secure the lower case.
Insert an opening pick into the gap between the lower case and chassis.
Slide the pick around the entire perimeter of the laptop until the lower case fully releases.
Remove the lower case.
Fast fertig!
Abschluss
