Zum Hauptinhalt wechseln
ASUS Chromebook C424MA-DH48F Speakers Replacement
Was du brauchst
  1. ASUS Chromebook C424MA-DH48F Speakers Replacement, Lower Case: Schritt 1, Bild 1 von 2 ASUS Chromebook C424MA-DH48F Speakers Replacement, Lower Case: Schritt 1, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the eleven 6.9 mm screws that secure the lower case.
    • Make sure all the screws on this side get taken out because there could be a label or warranty sticker covering up a screw that might be missed.
    • Insert an opening pick into the gap between the lower case and chassis.
    • Slide the pick around the entire perimeter of the laptop until the lower case fully releases.
    • Remove the lower case.
  2. ASUS Chromebook C424MA-DH48F Speakers Replacement, ASUS Chromebook C424MA-DH48F Battery Disconnection: Schritt 2, Bild 1 von 3 ASUS Chromebook C424MA-DH48F Speakers Replacement, ASUS Chromebook C424MA-DH48F Battery Disconnection: Schritt 2, Bild 2 von 3 ASUS Chromebook C424MA-DH48F Speakers Replacement, ASUS Chromebook C424MA-DH48F Battery Disconnection: Schritt 2, Bild 3 von 3
    • Use an opening tool to pop up the silver locking bar securing the battery connector.
    • Push the battery connector directly out of its motherboard port.
  3. ASUS Chromebook C424MA-DH48F Speakers Replacement, Speakers: Schritt 3, Bild 1 von 3 ASUS Chromebook C424MA-DH48F Speakers Replacement, Speakers: Schritt 3, Bild 2 von 3 ASUS Chromebook C424MA-DH48F Speakers Replacement, Speakers: Schritt 3, Bild 3 von 3
    • Use an opening tool or your fingernails to gently "walk" the speaker connector directly out of its motherboard socket.
  4. ASUS Chromebook C424MA-DH48F Speakers Replacement: Schritt 4, Bild 1 von 1
    • Lift the right speaker up and out of the chassis, with care not to strain the connected cable.
  5. ASUS Chromebook C424MA-DH48F Speakers Replacement: Schritt 5, Bild 1 von 1
    • Unseat the speaker wires from the lower side of the battery.
  6. ASUS Chromebook C424MA-DH48F Speakers Replacement: Schritt 6, Bild 1 von 1
    • Lift the left speaker up and out of the chassis.
Abschluss
Anthony Wink
401 Reputation
3 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 12
Insgesamt: 28
