Zum Hauptinhalt wechseln
ASUS Chromebook C424MA-DH48F Touchpad Replacement
Was du brauchst
  1. ASUS Chromebook C424MA-DH48F Touchpad Replacement, Lower Case: Schritt 1, Bild 1 von 2 ASUS Chromebook C424MA-DH48F Touchpad Replacement, Lower Case: Schritt 1, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the eleven 6.9 mm screws that secure the lower case.
    • Make sure all the screws on this side get taken out because there could be a label or warranty sticker covering up a screw that might be missed.
    • Insert an opening pick into the gap between the lower case and chassis.
    • Slide the pick around the entire perimeter of the laptop until the lower case fully releases.
    • Remove the lower case.
    Frag FixBot
    Kommentar hinzufügen
  2. ASUS Chromebook C424MA-DH48F Touchpad Replacement, ASUS Chromebook C424MA-DH48F Battery Disconnection: Schritt 2, Bild 1 von 3 ASUS Chromebook C424MA-DH48F Touchpad Replacement, ASUS Chromebook C424MA-DH48F Battery Disconnection: Schritt 2, Bild 2 von 3 ASUS Chromebook C424MA-DH48F Touchpad Replacement, ASUS Chromebook C424MA-DH48F Battery Disconnection: Schritt 2, Bild 3 von 3
    • Use an opening tool to pop up the silver locking bar securing the battery connector.
    • Push the battery connector directly out of its motherboard port.
    Frag FixBot
  3. ASUS Chromebook C424MA-DH48F Touchpad Replacement, Battery: Schritt 3, Bild 1 von 3 ASUS Chromebook C424MA-DH48F Touchpad Replacement, Battery: Schritt 3, Bild 2 von 3 ASUS Chromebook C424MA-DH48F Touchpad Replacement, Battery: Schritt 3, Bild 3 von 3
    • Carefully use the plastic prying tool and pop up the locking bar and lift the connector off with your hand.
    Frag FixBot
  4. ASUS Chromebook C424MA-DH48F Touchpad Replacement: Schritt 4, Bild 1 von 3 ASUS Chromebook C424MA-DH48F Touchpad Replacement: Schritt 4, Bild 2 von 3 ASUS Chromebook C424MA-DH48F Touchpad Replacement: Schritt 4, Bild 3 von 3
    • Use a Phillips #0 screwdriver to remove the six 4.1 mm screws that secure the battery.
    • The two screw holes (marked in orange) on the bottom won't have screws associated with them since they were removed earlier when the base was removed.
    • Unseat the speaker cable from the black plastic hooks on the lower side of the battery.
    • Lift the battery up and out of the chassis.
    Frag FixBot
  5. ASUS Chromebook C424MA-DH48F Touchpad Replacement, Touchpad: Schritt 5, Bild 1 von 1
    • Use a Phillips #000 screwdriver to remove the three 1.9 mm screws that secure the touchpad.
    Frag FixBot
  6. ASUS Chromebook C424MA-DH48F Touchpad Replacement: Schritt 6, Bild 1 von 1
    • Carefully peel off the gray tape on the touchpad.
    Frag FixBot
  7. ASUS Chromebook C424MA-DH48F Touchpad Replacement: Schritt 7, Bild 1 von 2 ASUS Chromebook C424MA-DH48F Touchpad Replacement: Schritt 7, Bild 2 von 2
    • Use an opening tool to flip up the black ZIF locking flap that secures the ribbon cable connector to the touchpad.
    • Pinch both sides of the ribbon cable connector and gently pull straight back to disconnect the touchpad.
    • Be very careful as the ribbon cable is fragile and can rip easily.
    Frag FixBot
  8. ASUS Chromebook C424MA-DH48F Touchpad Replacement: Schritt 8, Bild 1 von 3 ASUS Chromebook C424MA-DH48F Touchpad Replacement: Schritt 8, Bild 2 von 3 ASUS Chromebook C424MA-DH48F Touchpad Replacement: Schritt 8, Bild 3 von 3
    • Lift the touchpad up and out of the chassis.
    Frag FixBot
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 18
Insgesamt: 254
