Einleitung
If you have started noticing that your laptop loses power faster than before, or if it randomly shuts down when high on charge, a faulty battery is likely the cause. This guide will provide the necessary components and steps to remove and replace your E210MA battery.
Was du brauchst
Place the laptop with the bottom side facing up. Have the front (where the mousepad is) facing toward you.
Start by removing the ten 7mm screws on the bottom of the laptop using a JIS #00 JIS screwdriver.
Double-check to make sure all of the screws are removed.
If you have a Jimmy or other flat, straight-edge object, slide it in the crack where the halves of the case meet.
When the parts are separated, pull them apart to expose the insides of the case.
Remove the 3 mm screws around the battery.
Carefully lift up the USB port and set it to the side.
Unplug the connection between the motherboard and the battery by pulling towards the speaker side.
Repeat the same process to remove the blue tape on the second picture.
