Zum Hauptinhalt wechseln
ASUS E210MA-TB.CL464BK Battery Replacement
Was du brauchst
  1. ASUS E210MA-TB.CL464BK Battery Replacement, Battery: Schritt 1, Bild 1 von 3 ASUS E210MA-TB.CL464BK Battery Replacement, Battery: Schritt 1, Bild 2 von 3 ASUS E210MA-TB.CL464BK Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Place the laptop with the bottom side facing up. Have the front (where the mousepad is) facing toward you.
    • Start by removing the ten 7mm screws on the bottom of the laptop using a JIS #00 JIS screwdriver.
  2. ASUS E210MA-TB.CL464BK Battery Replacement: Schritt 2, Bild 1 von 1
    • Double-check to make sure all of the screws are removed.
    • If you have a Jimmy or other flat, straight-edge object, slide it in the crack where the halves of the case meet.
    • When the parts are separated, pull them apart to expose the insides of the case.
  3. ASUS E210MA-TB.CL464BK Battery Replacement: Schritt 3, Bild 1 von 2 ASUS E210MA-TB.CL464BK Battery Replacement: Schritt 3, Bild 2 von 2
    • Remove the 4 mm screws around the USB port.
  4. ASUS E210MA-TB.CL464BK Battery Replacement: Schritt 4, Bild 1 von 2 ASUS E210MA-TB.CL464BK Battery Replacement: Schritt 4, Bild 2 von 2
    • Remove the 3 mm screws around the battery.
    • Carefully lift up the USB port and set it to the side.
  5. ASUS E210MA-TB.CL464BK Battery Replacement: Schritt 5, Bild 1 von 2 ASUS E210MA-TB.CL464BK Battery Replacement: Schritt 5, Bild 2 von 2
    • Unplug the connection between the motherboard and the battery by pulling towards the speaker side.
    • Repeat the same process to remove the blue tape on the second picture.
  6. ASUS E210MA-TB.CL464BK Battery Replacement: Schritt 6, Bild 1 von 1
    • Lift up and remove the battery.
Abschluss
John Hutchins
763 Reputation
5 Anleitungen geschrieben
Gateway, Team 73-6, Gonzalez Spring 2023 Mitglied von Gateway, Team 73-6, Gonzalez Spring 2023
GCC-GONZALEZ-S23S73G6
5 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 30
Insgesamt: 436
