Einleitung
This is a touchpad replacement guide for the ASUS E210MA-TB.CL464BK, sometimes just referred to as E210MA. The part allows the user to move around the mouse and functions as a numpad. The added complexity of the touchpad means that it is particularly susceptible to losing sensitivity so the user may want to replace it.
Was du brauchst
Place the laptop with the bottom side facing up. Have the front (where the touchpad is) facing toward you.
Start by removing the ten 7mm screws on the bottom of the laptop using a JIS #00 screwdriver.
Double-check to make sure all of the screws are removed.
If you have a Jimmy or other flat, straight-edge object, slide it in the crack where the halves of the case meet.
When the parts are separated, pull them apart to expose the insides of the case.
Remove the speakers as outlined in the speaker replacement guide, summarized below.
Remove the four 5mm screws, with a J00 screw driver.
Locate and remove the white plug by pulling it towards you.
Remove the usb port as outlined in the usb port replacement guide, summarized below.
Remove the four 5mm screws with a J00 screwdriver.
You do not *need* to fully unplug and remove the USB port, but at least it is out of the way.
Remove the battery as described in the battery replacement guide, summarized below.
Remove the five 5mm screws securing the battery with a J00 screwdriver.
Unplug and disconnect the tape.
Identify the touchpad at the front of the case.
Unplug and remove the tape from the top of the touchpad.
Remove the three 5mm screws from the top of the touchpad with a J00 screwdriver.
Slide out the touchpad from under the metal bracket.pinching the top and sliding it forward and up.
