Einleitung
If your laptop is having trouble with identifying external USB devices, you may have to replace the port. After ensuring that it is not a software issue, you can use these steps to remove the USB port board.
Was du brauchst
Place the laptop with the bottom side facing up. Have the front (where the touchpad is) facing toward you.
Start by removing the ten 7mm screws on the bottom of the laptop using a JIS #00 screwdriver.
Double-check to make sure all of the screws are removed.
If you have a Jimmy or other flat, straight-edge object, slide it in the crack where the halves of the case meet.
When the parts are separated, pull them apart to expose the insides of the case.
