Zum Hauptinhalt wechseln
ASUS EEE PC701SD-WHI004X Keyboard Replacement
Was du brauchst
  1. ASUS EEE PC701SD-WHI004X Keyboard Replacement, Battery: Schritt 1, Bild 1 von 2 ASUS EEE PC701SD-WHI004X Keyboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Flip the laptop over, you should see two battery tabs.
    • Slide the right tab towards the right. The orange dot should be visible. This tab will be locked open.
  2. ASUS EEE PC701SD-WHI004X Keyboard Replacement: Schritt 2, Bild 1 von 2 ASUS EEE PC701SD-WHI004X Keyboard Replacement: Schritt 2, Bild 2 von 2
    • While holding the left tab towards the left. Gently slide the battery out of the laptop.
  3. ASUS EEE PC701SD-WHI004X Keyboard Replacement, Keyboard: Schritt 3, Bild 1 von 3 ASUS EEE PC701SD-WHI004X Keyboard Replacement, Keyboard: Schritt 3, Bild 2 von 3 ASUS EEE PC701SD-WHI004X Keyboard Replacement, Keyboard: Schritt 3, Bild 3 von 3
    • Push the 3 tabs at the top of the keyboard in and down one at a time using a nylon spudger.
    • Once the three tabs have been pushed in, gently pry the top of the keyboard until it begins to hinge out of its slot.
    • The keyboard is still attached by a cable. Be careful when removing not to damage the cable. Do not yank the keyboard out.
  4. ASUS EEE PC701SD-WHI004X Keyboard Replacement: Schritt 4, Bild 1 von 3 ASUS EEE PC701SD-WHI004X Keyboard Replacement: Schritt 4, Bild 2 von 3 ASUS EEE PC701SD-WHI004X Keyboard Replacement: Schritt 4, Bild 3 von 3
    • Push the two sides of the ribbon cable connector away from yourself. This will unseat the ribbon cable.
    • Once the tabs are unseated, you can gently remove the ribbon cable by pulling it out of its slot. The keyboard can now be removed.
    • To be on the safe side, it’s better to use a nylon spudger, rather than the metal spudger shown in the picture.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
mir
409 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S2-G8, Isaacson Spring 2017 Mitglied von UMass Dartmouth, Team S2-G8, Isaacson Spring 2017
UMASSD-ISAACSON-S17S2G8
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 494
