Einleitung
This repair might be necessary for any type of faulty hard drive that may not be functioning correctly. In order to replace the hard drive, be prepared to use a few tools, and be cautious with small fragile parts when taking apart the device.
Was du brauchst
Remove the four 4.76 mm Philips screws on the back of the laptop using the Phillips J0 Screwdriver.
Starting from the left, use a plastic opening tool to slide the hard drive all the way to the right.
Once the hard drive is completely to the right, pull up on the hard drive to remove.
Eine weitere Person hat diese Anleitung absolviert.
