Zum Hauptinhalt wechseln
ASUS Eee Pad Transformer Back Facing Camera Replacement
Was du brauchst
  1. ASUS Eee Pad Transformer Back Facing Camera Replacement, Back Panel: Schritt 1, Bild 1 von 2 ASUS Eee Pad Transformer Back Facing Camera Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Use T5 Torx Screwdriver to remove two 4.5 millimeter T5 screws on either side of the port on the bottom of the tablet.
  2. ASUS Eee Pad Transformer Back Facing Camera Replacement: Schritt 2, Bild 1 von 3 ASUS Eee Pad Transformer Back Facing Camera Replacement: Schritt 2, Bild 2 von 3 ASUS Eee Pad Transformer Back Facing Camera Replacement: Schritt 2, Bild 3 von 3
    • Use the Plastic Opening Tool to pry between the main tablet body and the outer rim casing. Remove the outer rim casing by prying all the way around the device and pulling the rim upward.
    • The physical buttons are located on the outside of the rim on the right side, proceed with the guide to locate internal buttons.
  3. ASUS Eee Pad Transformer Back Facing Camera Replacement: Schritt 3, Bild 1 von 1
    • Remove the four 2 millimeter Phillips #00 screws at the corners of the tablet.
  4. ASUS Eee Pad Transformer Back Facing Camera Replacement: Schritt 4, Bild 1 von 1
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found above the camera area, on the top portion of the tablet.
  5. ASUS Eee Pad Transformer Back Facing Camera Replacement: Schritt 5, Bild 1 von 1
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found on the bottom portion of the tablet near the port.
  6. ASUS Eee Pad Transformer Back Facing Camera Replacement: Schritt 6, Bild 1 von 2 ASUS Eee Pad Transformer Back Facing Camera Replacement: Schritt 6, Bild 2 von 2
    • Remove back panel by pulling away from the remaining device.
  7. ASUS Eee Pad Transformer Back Facing Camera Replacement, Pull out flap: Schritt 7, Bild 1 von 2 ASUS Eee Pad Transformer Back Facing Camera Replacement, Pull out flap: Schritt 7, Bild 2 von 2
    • Use Tweezers to pull out gold flap connected to bottom of camera.
    • Pull the gold flap to take out the camera.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Sandy Babich
1.885 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 13-9, Forte Fall 2014 Mitglied von Cal Poly, Team 13-9, Forte Fall 2014
CPSU-FORTE-F14S13G9
5 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,112
