Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
Repairing a damaged back panel is very important, the back panel protects all the inner workings in the tablet and needs to be in good condition to prevent permanent damage in the device. Removing the back panel also allows access to everything inside of the device and is an essential first step to all other repairs involved with the TF101 Tablet.
  1. Use T5 Torx Screwdriver to remove two 4.5 millimeter T5 screws on either side of the port on the bottom of the tablet. Use T5 Torx Screwdriver to remove two 4.5 millimeter T5 screws on either side of the port on the bottom of the tablet.
    • Use T5 Torx Screwdriver to remove two 4.5 millimeter T5 screws on either side of the port on the bottom of the tablet.
  2. Use the Plastic Opening Tool to pry between the main tablet body and the outer rim casing. Remove the outer rim casing by prying all the way around the device and pulling the rim upward. The physical buttons are located on the outside of the rim on the right side, proceed with the guide to locate internal buttons. The physical buttons are located on the outside of the rim on the right side, proceed with the guide to locate internal buttons.
    • Use the Plastic Opening Tool to pry between the main tablet body and the outer rim casing. Remove the outer rim casing by prying all the way around the device and pulling the rim upward.
    • The physical buttons are located on the outside of the rim on the right side, proceed with the guide to locate internal buttons.
  3. Nintendo Switch Kits
    Eine schnelle Lösung, um wieder ins Spiel zu kommen
    Switch Kits kaufen
    Switch Kits kaufen
  4. Remove the four 2 millimeter Phillips #00 screws at the corners of the tablet.
    • Remove the four 2 millimeter Phillips #00 screws at the corners of the tablet.
  5. Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found above the camera area, on the top portion of the tablet.
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found above the camera area, on the top portion of the tablet.
  6. Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found on the bottom portion of the tablet near the port.
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found on the bottom portion of the tablet near the port.
  7. Remove back panel by pulling away from the remaining device. Remove back panel by pulling away from the remaining device.
    • Remove back panel by pulling away from the remaining device.
Abschluss
3 weitere Nutzer haben diese Anleitung absolviert.
Sandy Babich
1.739 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 13-9, Forte Fall 2014 Mitglied von Cal Poly, Team 13-9, Forte Fall 2014
CPSU-FORTE-F14S13G9
5 Mitglieder
12 Anleitungen geschrieben
what can I use to stick back the metalic edge?
Cathy Madzimure - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 4
Letzten 30 Tage: 28
Insgesamt: 3,194
