Zum Hauptinhalt wechseln
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the battery, using release clips. Ensure device has no residual power by attempting boot once battery is removed.
    • Remove the battery, using release clips.
    • Ensure device has no residual power by attempting boot once battery is removed.
    • Remove either 2 (or 4 for a full teardown) 12mm phillips screws, then removing the bottom cover to gain access to the HDD and RAM.
    • Remove HDD and RAM cover
  2. Remove 3 5mm Phillips screws
    • Remove 3 5mm Phillips screws
    • Slide HDD caddy back, remove using the black pull tab.
  3. Remove 4 Phillips screws, 2 per side
    • Remove 4 Phillips screws, 2 per side
    • Remove HDD from caddy.
  4. Remove 7 5mm Phillips screws
    • Remove 7 5mm Phillips screws
  5. Flip laptop and open lid. Separate the keyboard plate from the main housing, using a plastic prying tool. Being careful not to damage the LED indicators or other peripheries. Disconnect the LED, trackpad, and keyboard ribbon cables. The keyboard can now be removed
    • Flip laptop and open lid. Separate the keyboard plate from the main housing, using a plastic prying tool. Being careful not to damage the LED indicators or other peripheries.
    • Disconnect the LED, trackpad, and keyboard ribbon cables.
    • The keyboard can now be removed
  6. Locate Wifi Card Remove the antenna cables using a spudger tool.
    • Locate Wifi Card
    • Remove the antenna cables using a spudger tool.
    • Remove the Philips screw The Wifi Card will pop up and should be easily removed.
Abschluss
4 weitere Nutzer haben diese Anleitung absolviert.
Ryan
1.414 Reputation
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 3
Letzten 7 Tage: 11
Letzten 30 Tage: 47
Insgesamt: 5,511
