Zum Hauptinhalt wechseln
ASUS F555UA-EH71 Battery Replacement
Was du brauchst
  1. ASUS F555UA-EH71 Battery Replacement, Keyboard Panel: Schritt 1, Bild 1 von 1
    • Remove the ten 18 mm screws holding down the outer shell of the laptop using the Phillips #000 screwdriver.
  2. ASUS F555UA-EH71 Battery Replacement: Schritt 2, Bild 1 von 2 ASUS F555UA-EH71 Battery Replacement: Schritt 2, Bild 2 von 2
    • Use your fingers to gently pry open the gap between the silver and black parts of the casing.
    • Separate the keyboard panel from the body of the laptop by wedging the iFixit Opening Tool in between the keyboard panel and the body.
    • The teeth of the casing should make a clicking noise as they’re pulled apart.
  3. ASUS F555UA-EH71 Battery Replacement: Schritt 3, Bild 1 von 1
    • Gently open the casing until the white, silver, and gold power strips are visible. Gently peel the strips from the bottom side of the laptop.
    • Disconnect the two cables connecting the keyboard panel to the laptop.
  4. ASUS F555UA-EH71 Battery Replacement: Schritt 4, Bild 1 von 1
    • Remove the keyboard panel from the laptop.
  5. ASUS F555UA-EH71 Battery Replacement, Battery: Schritt 5, Bild 1 von 3 ASUS F555UA-EH71 Battery Replacement, Battery: Schritt 5, Bild 2 von 3 ASUS F555UA-EH71 Battery Replacement, Battery: Schritt 5, Bild 3 von 3
    • Use the Phillips #000 screwdriver to remove the eight 4 mm screws holding the battery in place.
  6. ASUS F555UA-EH71 Battery Replacement: Schritt 6, Bild 1 von 2 ASUS F555UA-EH71 Battery Replacement: Schritt 6, Bild 2 von 2
    • Carefully remove the battery from the device.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 16
Insgesamt: 948
