Zum Hauptinhalt wechseln
ASUS G713RC RAM Replacement
Was du brauchst
  1. ASUS G713RC RAM Replacement, RAM: Schritt 1, Bild 1 von 3 ASUS G713RC RAM Replacement, RAM: Schritt 1, Bild 2 von 3 ASUS G713RC RAM Replacement, RAM: Schritt 1, Bild 3 von 3
    • Warning: Do not touch any other components inside if you don't have to. It may result in damage and can destroy your laptop.
    • Remove the seven large screws using a Phillips #00 screwdriver.
    • Remove the four small screws using a Phillips #00 screwdriver.
    • Carefully lift the lid, being careful of the two cables connected to the laptop.
  2. ASUS G713RC RAM Replacement: Schritt 2, Bild 1 von 3 ASUS G713RC RAM Replacement: Schritt 2, Bild 2 von 3 ASUS G713RC RAM Replacement: Schritt 2, Bild 3 von 3
    • Carefully detach the two white cables that are connected to the lid.
    • Set aside the lid.
  3. ASUS G713RC RAM Replacement: Schritt 3, Bild 1 von 3 ASUS G713RC RAM Replacement: Schritt 3, Bild 2 von 3 ASUS G713RC RAM Replacement: Schritt 3, Bild 3 von 3
    • Carefully lift up each gray bar.
    • It is important that you don't completely remove the gray bar.
    • Remove the RAM.
  4. ASUS G713RC RAM Replacement: Schritt 4, Bild 1 von 3 ASUS G713RC RAM Replacement: Schritt 4, Bild 2 von 3 ASUS G713RC RAM Replacement: Schritt 4, Bild 3 von 3
    • Insert each RAM stick under the gray bar. Push until you hear a click.
    • Hold down the gray bar to make sure it is flat and secure.
    • It might be a bit bumpy, but it is nothing to worry about.
  5. ASUS G713RC RAM Replacement: Schritt 5, Bild 1 von 2 ASUS G713RC RAM Replacement: Schritt 5, Bild 2 von 2
    • Reattach the lid by connecting the white wires to the base.
    • Plug in the white wires on both sides. You want to plug them in thoroughly, otherwise, your laptop won't turn on.
  6. ASUS G713RC RAM Replacement: Schritt 6, Bild 1 von 2 ASUS G713RC RAM Replacement: Schritt 6, Bild 2 von 2
    • Line up the lid to the laptop.
    • Tighten the seven large screws using a Phillips #00 screwdriver.
    • Tighten the four small screws using a Phillips #00 screwdriver.
Ziellinie
Eine weitere Person hat diese Anleitung absolviert.
Javier Bobadilla
157 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 4-99, Harris Fall 2024 Mitglied von CSU Los Angeles, Team 4-99, Harris Fall 2024
CSULA-HARRIS-F24S4G99
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 60
Letzte 30 Tage: 123
Insgesamt: 203
