Zum Hauptinhalt wechseln
ASUS K53E-BBR1 Hard Drive Replacement
Was du brauchst
  1. ASUS K53E-BBR1 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the laptop over so you can see the battery.
  2. ASUS K53E-BBR1 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Slide the lock on the right side of the battery to the right. If done correctly the slider will stay in place and there will be a red indicator.
  3. ASUS K53E-BBR1 Hard Drive Replacement: Schritt 3, Bild 1 von 3 ASUS K53E-BBR1 Hard Drive Replacement: Schritt 3, Bild 2 von 3 ASUS K53E-BBR1 Hard Drive Replacement: Schritt 3, Bild 3 von 3
    • Slide the other sliding lock on the left side of the battery to the left, and with your other hand slide the battery out from the laptop.
  4. ASUS K53E-BBR1 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 2 ASUS K53E-BBR1 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 2 von 2
    • Remove the two 4mm Phillips #0 screws on either side of the laptop.
  5. ASUS K53E-BBR1 Hard Drive Replacement: Schritt 5, Bild 1 von 2 ASUS K53E-BBR1 Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Slide the back panel towards you until it stops.
    • Lift the panel up out of the laptop casing.
  6. ASUS K53E-BBR1 Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Remove the four 3mm Phillips #0 screws holding the hard drive in place.
  7. ASUS K53E-BBR1 Hard Drive Replacement: Schritt 7, Bild 1 von 1
    • Disconnect the hard drive from the laptop by sliding it towards the outside edge.
  8. ASUS K53E-BBR1 Hard Drive Replacement: Schritt 8, Bild 1 von 2 ASUS K53E-BBR1 Hard Drive Replacement: Schritt 8, Bild 2 von 2
    • Grab hold of the black cloth tab and pull the hard drive out from the laptop.
Abschluss
Matthew Merlo
267 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S6-G4, Peak Spring 2019 Mitglied von UMass Dartmouth, Team S6-G4, Peak Spring 2019
UMASSD-PEAK-S19S6G4
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 267
