Zum Hauptinhalt wechseln
ASUS K53E-BBR1 Keyboard Replacement
Was du brauchst
  1. ASUS K53E-BBR1 Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Lift the monitor up so that the keyboard is visible.
    • You will notice five spots on the top of the keyboard where the iFixit opening tool should be placed.
  2. ASUS K53E-BBR1 Keyboard Replacement: Schritt 2, Bild 1 von 3 ASUS K53E-BBR1 Keyboard Replacement: Schritt 2, Bild 2 von 3 ASUS K53E-BBR1 Keyboard Replacement: Schritt 2, Bild 3 von 3
    • Use the iFixit opening tool on each of the designated spots to pry the keyboard apart from the palm rest.
    • You will hear a light "pop" sound each time you pry the keyboard.
    • Once the keyboard is loose, do not pull keyboard far (more than 3 inches) apart from the from the palm rest. There is a "bus" connector attached to the bottom.
  3. ASUS K53E-BBR1 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Carefully disconnect the "bus" connector from the laptop. Press on it with your thumb/index finger and slide it right along the surface of the laptop.
Abschluss
Paulo Fortes
147 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S6-G4, Peak Spring 2019 Mitglied von UMass Dartmouth, Team S6-G4, Peak Spring 2019
UMASSD-PEAK-S19S6G4
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 12
Insgesamt: 328
