Zum Hauptinhalt wechseln
ASUS K53E-BBR1 RAM Replacement
Was du brauchst
  1. ASUS K53E-BBR1 RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the laptop over so you can see the battery.
  2. ASUS K53E-BBR1 RAM Replacement: Schritt 2, Bild 1 von 1
    • Slide the lock on the right side of the battery to the right. If done correctly the slider will stay in place and there will be a red indicator.
  3. ASUS K53E-BBR1 RAM Replacement: Schritt 3, Bild 1 von 3 ASUS K53E-BBR1 RAM Replacement: Schritt 3, Bild 2 von 3 ASUS K53E-BBR1 RAM Replacement: Schritt 3, Bild 3 von 3
    • Slide the other sliding lock on the left side of the battery to the left, and with your other hand slide the battery out from the laptop.
  4. ASUS K53E-BBR1 RAM Replacement, RAM: Schritt 4, Bild 1 von 2 ASUS K53E-BBR1 RAM Replacement, RAM: Schritt 4, Bild 2 von 2
    • Remove the two 4mm Phillips #0 screws located on the opposite ends of the laptop.
  5. ASUS K53E-BBR1 RAM Replacement: Schritt 5, Bild 1 von 2 ASUS K53E-BBR1 RAM Replacement: Schritt 5, Bild 2 von 2
    • Slide the back panel backwards until it stops.
    • You can now lift the panel up and out of the laptop casing.
  6. ASUS K53E-BBR1 RAM Replacement: Schritt 6, Bild 1 von 3 ASUS K53E-BBR1 RAM Replacement: Schritt 6, Bild 2 von 3 ASUS K53E-BBR1 RAM Replacement: Schritt 6, Bild 3 von 3
    • The RAM is now visible.
    • Remove the RAM by pressing out on both tabs visible on each side of the RAM.
    • To work the tabs, take your finger tips and press outwards from the indents on the RAM.
  7. ASUS K53E-BBR1 RAM Replacement: Schritt 7, Bild 1 von 2 ASUS K53E-BBR1 RAM Replacement: Schritt 7, Bild 2 von 2
    • The RAM is now angled up and you can remove the RAM by pulling it out in the direction it is facing.
    • Gently Pull the RAM out of its connector without pushing down or pulling up.
  8. ASUS K53E-BBR1 RAM Replacement: Schritt 8, Bild 1 von 3 ASUS K53E-BBR1 RAM Replacement: Schritt 8, Bild 2 von 3 ASUS K53E-BBR1 RAM Replacement: Schritt 8, Bild 3 von 3
    • Repeat the previous two steps for the second stick of RAM.
Abschluss
UMass Dartmouth, Team S6-G4, Peak Spring 2019 Mitglied von UMass Dartmouth, Team S6-G4, Peak Spring 2019
UMASSD-PEAK-S19S6G4
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 208
