Zum Hauptinhalt wechseln
ASUS MeMo Pad FHD10 Camera Replacement
Was du brauchst
  1. ASUS MeMo Pad FHD10 Camera Replacement, Battery: Schritt 1, Bild 1 von 2 ASUS MeMo Pad FHD10 Camera Replacement, Battery: Schritt 1, Bild 2 von 2
    • Make sure that the device is turned off as a precaution.
    • Unplug the charger and remove any memory card you may have in the device.
    • Wedge the plastic opening tool between the front and back cover on every side.
    • Slide the plastic opening tool back and forth to make sure that the back cover is disconnected.
    • Once disconnected, remove the back cover from the device screen.
  2. ASUS MeMo Pad FHD10 Camera Replacement: Schritt 2, Bild 1 von 2 ASUS MeMo Pad FHD10 Camera Replacement: Schritt 2, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove the protective copper sticker and all tape fixed on the device.
    • Using tweezers, remove the ribbon cable from their connections attached to the motherboard.
    • While using the tweezers, make sure to use minimum force and precision to avoid damaging any components.
  3. ASUS MeMo Pad FHD10 Camera Replacement: Schritt 3, Bild 1 von 2 ASUS MeMo Pad FHD10 Camera Replacement: Schritt 3, Bild 2 von 2
    • Remove the four 2 mm Phillips #00 screws holding the battery tray in place.
  4. ASUS MeMo Pad FHD10 Camera Replacement: Schritt 4, Bild 1 von 3 ASUS MeMo Pad FHD10 Camera Replacement: Schritt 4, Bild 2 von 3 ASUS MeMo Pad FHD10 Camera Replacement: Schritt 4, Bild 3 von 3
    • Locate the battery cable attached to the motherboard. Using the same technique used on the ribbons, do the same with the battery.
    • Remove the battery from the device. Once removed, use the plastic tool to separate the metal frame from the battery.
    • When separating the metal frame, be sure to hold on in the center as the battery is two separate cells.
  5. ASUS MeMo Pad FHD10 Camera Replacement, Speakers: Schritt 5, Bild 1 von 1
    • Remove three screws using a Phillips #00 screwdriver.
  6. ASUS MeMo Pad FHD10 Camera Replacement: Schritt 6, Bild 1 von 1
    Kaufen
    • The two speakers are located on opposite sides of the device. Both are long black pieces with connections to the motherboard.
    • Unplug the speaker cables from their connections on the motherboard gently by using tweezers.
  7. ASUS MeMo Pad FHD10 Camera Replacement: Schritt 7, Bild 1 von 3 ASUS MeMo Pad FHD10 Camera Replacement: Schritt 7, Bild 2 von 3 ASUS MeMo Pad FHD10 Camera Replacement: Schritt 7, Bild 3 von 3
    • Gently use your hands to remove the speakers.
  8. ASUS MeMo Pad FHD10 Camera Replacement, Motherboard: Schritt 8, Bild 1 von 1
    • Remove the five screws using a Phillips #00 screwdriver.
  9. ASUS MeMo Pad FHD10 Camera Replacement: Schritt 9, Bild 1 von 3 ASUS MeMo Pad FHD10 Camera Replacement: Schritt 9, Bild 2 von 3 ASUS MeMo Pad FHD10 Camera Replacement: Schritt 9, Bild 3 von 3
    • Carefully disconnect the cord that connects the on/off button to the motherboard
    • Peel back the electrical tape holding the connections of the motherboard down to the frame of the device.
  10. ASUS MeMo Pad FHD10 Camera Replacement: Schritt 10, Bild 1 von 1
    • Use your hands to remove the motherboard from the device.
  11. ASUS MeMo Pad FHD10 Camera Replacement, Front and Rear cameras.: Schritt 11, Bild 1 von 1
    • Identify the location of front and rear cameras on the motherboard.
  12. ASUS MeMo Pad FHD10 Camera Replacement: Schritt 12, Bild 1 von 2 ASUS MeMo Pad FHD10 Camera Replacement: Schritt 12, Bild 2 von 2
    • The front and rear cameras can be removed by pulling them out gently using hands.
Abschluss
Dmitry
391 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 9-5, Blackwell Winter 2015 Mitglied von USF Tampa, Team 9-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G5
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 583
