Einleitung
The removal of the battery is an essential bit of knowledge, since you will have to do this before most other repairs. Removing the battery first creates a safe environment to work in, which will eliminate most shock hazards.
Was du brauchst
Turn the laptop off and unplug all cables.
Flip over so the bottom is facing you.
Remove the ten 3mm Torx T5 screws from the bottom cover.
Use a spudger to wedge between the laptop and bottom cover—lift upwards to pry open.
Run the spudger along the perimeter of the bottom cover to remove.
4 weitere Personen haben diese Anleitung absolviert.
