Einleitung
This guide will show how to remove and replace the RAM on your Asus N550JK-DS71T laptop.
Was du brauchst
Turn the laptop off and unplug all cables.
Flip over so the bottom is facing you.
Remove the ten 3mm Torx T5 screws from the bottom cover.
Use a spudger to wedge between the laptop and bottom cover—lift upwards to pry open.
Run the spudger along the perimeter of the bottom cover to remove.
Put on anti-static wristband and attach clip-end to any metal screw insert.
The RAM will be secured by two metal clips surrounded by white plastic.
Spread the metal clips and the RAM stick will pop up. Then gently remove the RAM stick.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
