Zum Hauptinhalt wechseln
ASUS N550JK-DS71T Laptop RAM stick Replacement
Was du brauchst
  1. ASUS N550JK-DS71T Laptop RAM stick Replacement, Back Case: Schritt 1, Bild 1 von 2 ASUS N550JK-DS71T Laptop RAM stick Replacement, Back Case: Schritt 1, Bild 2 von 2
    • Turn the laptop off and unplug all cables.
    • Flip over so the bottom is facing you.
    • Remove the ten 3mm Torx T5 screws from the bottom cover.
  2. ASUS N550JK-DS71T Laptop RAM stick Replacement: Schritt 2, Bild 1 von 2 ASUS N550JK-DS71T Laptop RAM stick Replacement: Schritt 2, Bild 2 von 2
    • Use a spudger to wedge between the laptop and bottom cover—lift upwards to pry open.
    • Run the spudger along the perimeter of the bottom cover to remove.
  3. ASUS N550JK-DS71T Laptop RAM stick Replacement, Battery: Schritt 3, Bild 1 von 2 ASUS N550JK-DS71T Laptop RAM stick Replacement, Battery: Schritt 3, Bild 2 von 2
    • Remove the three 4mm JIS #0 screws from the battery.
  4. ASUS N550JK-DS71T Laptop RAM stick Replacement: Schritt 4, Bild 1 von 2 ASUS N550JK-DS71T Laptop RAM stick Replacement: Schritt 4, Bild 2 von 2
    • Using both hands, lift the battery vertically out of the device.
  5. ASUS N550JK-DS71T Laptop RAM stick Replacement, RAM Stick: Schritt 5, Bild 1 von 1
    • Put on anti-static wristband and attach clip-end to any metal screw insert.
    • The wristband is recommended when working closely with circuit boards due to potential static discharge.
  6. ASUS N550JK-DS71T Laptop RAM stick Replacement: Schritt 6, Bild 1 von 3 ASUS N550JK-DS71T Laptop RAM stick Replacement: Schritt 6, Bild 2 von 3 ASUS N550JK-DS71T Laptop RAM stick Replacement: Schritt 6, Bild 3 von 3
    • The RAM will be secured by two metal clips surrounded by white plastic.
    • Spread the metal clips and the RAM stick will pop up. Then gently remove the RAM stick.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Steven Hahn
884 Reputation
6 Anleitungen geschrieben
USF Tampa, Team S5-G1, Passmore Spring 2018 Mitglied von USF Tampa, Team S5-G1, Passmore Spring 2018
USFT-PASSMORE-S18S5G1
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 1,178
