Einleitung
If you want to upgrade storage space, this guide will show you how to replace the hard drive. Be sure the hard drive length is 2.5" and width is 9.5 mm. Also the connection of the hard drive must be SATA3.
Was du brauchst
Remove the one screw securing the back cover.
Pry off the cover using a finger.
Remove the screws securing hard drive to the laptop.
Pull out the hard drive from the connector.
Replace with a new hard drive.
