Einleitung
If you want to upgrade memory, this guide will show you how to replace the RAM. Be sure the type of RAM used is DDR3L SDRAM.
Was du brauchst
Remove the one screw securing the back cover.
Pry off the cover using a finger.
Push the clips outwards using two fingers.
Lift the RAM to remove it from the slot.
Fast fertig!
Abschluss
