Zum Hauptinhalt wechseln
ASUS PadFone X Front Facing Camera Replacement
Was du brauchst
  1. ASUS PadFone X Front Facing Camera  Replacement, Motherboard: Schritt 1, Bild 1 von 2 ASUS PadFone X Front Facing Camera  Replacement, Motherboard: Schritt 1, Bild 2 von 2
    • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose.
  2. ASUS PadFone X Front Facing Camera  Replacement: Schritt 2, Bild 1 von 2 ASUS PadFone X Front Facing Camera  Replacement: Schritt 2, Bild 2 von 2
    • Remove the thirteen 3.6 mm screws using the Torx T5 bit in the screwdriver.
  3. ASUS PadFone X Front Facing Camera  Replacement: Schritt 3, Bild 1 von 2 ASUS PadFone X Front Facing Camera  Replacement: Schritt 3, Bild 2 von 2
    • Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose and remove the mid-frame.
  4. ASUS PadFone X Front Facing Camera  Replacement: Schritt 4, Bild 1 von 1
    • Using the plastic blue plastic opening tool, gently disconnect the battery cable from the motherboard.
    • Applying too much force will damage the connector.
  5. ASUS PadFone X Front Facing Camera  Replacement: Schritt 5, Bild 1 von 2 ASUS PadFone X Front Facing Camera  Replacement: Schritt 5, Bild 2 von 2
    • Use the blue plastic opening tool to pry the battery pack from the phone. Pry along edge away from the motherboard as this might damage the motherboard.
    • The battery pack is held on by double sided tape, you will have to apply some force when prying out the battery.
  6. ASUS PadFone X Front Facing Camera  Replacement: Schritt 6, Bild 1 von 1
    • Using a spudger, pry the vibration motor connector from the motherboard.
  7. ASUS PadFone X Front Facing Camera  Replacement: Schritt 7, Bild 1 von 1
    • Use the blue plastic opening tool to gently pry the camera connector up from its socket on the motherboard.
    • Applying too much force will damage the conector
  8. ASUS PadFone X Front Facing Camera  Replacement: Schritt 8, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Using the tweezers, remove the rear camera from the Padfone X.
    • The camera is lightly glued to the motherboard. You may need to use a plastic opening tool to loosen the adhesive under the camera.
  9. ASUS PadFone X Front Facing Camera  Replacement: Schritt 9, Bild 1 von 2 ASUS PadFone X Front Facing Camera  Replacement: Schritt 9, Bild 2 von 2
    • Insert the tip of the flat head screwdriver between the panel and the metal clip then gently push down until the clip is slightly bent away from the panel.
    • Do this for all the clips holding the panel down.
    • After all clips are bent away, remove the panel.
  10. ASUS PadFone X Front Facing Camera  Replacement: Schritt 10, Bild 1 von 2 ASUS PadFone X Front Facing Camera  Replacement: Schritt 10, Bild 2 von 2
    • Disconnect the first connector by prying it upward using the blue plastic opening tool.
    • Disconnect the second connector by first lifting the lock then pulling the connector outward.
  11. ASUS PadFone X Front Facing Camera  Replacement: Schritt 11, Bild 1 von 3 ASUS PadFone X Front Facing Camera  Replacement: Schritt 11, Bild 2 von 3 ASUS PadFone X Front Facing Camera  Replacement: Schritt 11, Bild 3 von 3
    • Insert the tip of the blue plastic opening tool under the motherboard and gently pry upward.
    • Work your way around until the motherboard is free.
  12. ASUS PadFone X Front Facing Camera  Replacement: Schritt 12, Bild 1 von 1
    • Flip the motherboard over and locate the front facing camera.
    • Using the tweezers gently remove the black locking mechanism.
    • The black locking mechanism is very fragile and extreme care should be exercised during removal.
  13. ASUS PadFone X Front Facing Camera  Replacement: Schritt 13, Bild 1 von 2 ASUS PadFone X Front Facing Camera  Replacement: Schritt 13, Bild 2 von 2
    • Use the tweezers to gently pull on the connector to remove the camera.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
IUPUI, Team 2-1, Baechle Spring 2017 Mitglied von IUPUI, Team 2-1, Baechle Spring 2017
IUPUI-BAECHLE-S17S2G1
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 309
