Zum Hauptinhalt wechseln
Einleitung
This guide will show how to remove the back cover, with the integrated antenna, to replace it.
  1. Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upwards. Work your way around the phone until the entire back cover is loose.
    • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose.
  2. Replace the back cover with the new one; the antenna is integrated with the back panel.
    • Replace the back cover with the new one; the antenna is integrated with the back panel.
Abschluss
John Kue
379 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 8-4, Leahy Fall 2014 Mitglied von USF Tampa, Team 8-4, Leahy Fall 2014
USFT-LEAHY-F14S8G4
4 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 896
