Zum Hauptinhalt wechseln
ASUS PadFone X Station Docking Connector Replacement
Was du brauchst
  1. ASUS PadFone X Station Docking Connector Replacement, Back Cover: Schritt 1, Bild 1 von 2 ASUS PadFone X Station Docking Connector Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Using the plastic opening tools, insert it into the edge and pry open.
    • Use hands to help pull the back off from the front if needed.
  2. ASUS PadFone X Station Docking Connector Replacement, USB connector: Schritt 2, Bild 1 von 2 ASUS PadFone X Station Docking Connector Replacement, USB connector: Schritt 2, Bild 2 von 2
    • Locate the CON101
    • The white sticker indicates water exposure. White=none, Red=Exposure
  3. ASUS PadFone X Station Docking Connector Replacement, Remove two Phillips screws: Schritt 3, Bild 1 von 1
    • Remove two Phillips screws
  4. ASUS PadFone X Station Docking Connector Replacement, Locate P92L on CON1504: Schritt 4, Bild 1 von 2 ASUS PadFone X Station Docking Connector Replacement, Locate P92L on CON1504: Schritt 4, Bild 2 von 2
    • Locate P92L on CON1504
    • Gently peel back and remove plastic tape
  5. ASUS PadFone X Station Docking Connector Replacement, Removal of P92L: Schritt 5, Bild 1 von 3 ASUS PadFone X Station Docking Connector Replacement, Removal of P92L: Schritt 5, Bild 2 von 3 ASUS PadFone X Station Docking Connector Replacement, Removal of P92L: Schritt 5, Bild 3 von 3
    • Gently Pull P92L With Fingers From CON1504
  6. ASUS PadFone X Station Docking Connector Replacement, Identification of Antenna Wires: Schritt 6, Bild 1 von 1
    • These are the antenna wires.
    • Trace these wires to locate the two antennas.
  7. ASUS PadFone X Station Docking Connector Replacement, Desolder the two antenna wires: Schritt 7, Bild 1 von 2 ASUS PadFone X Station Docking Connector Replacement, Desolder the two antenna wires: Schritt 7, Bild 2 von 2
    • Locate the two antennas
    • Desolder the two antenna wires
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Daniel
338 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 7-4, Leahy Fall 2014 Mitglied von USF Tampa, Team 7-4, Leahy Fall 2014
USFT-LEAHY-F14S7G4
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,486
