Zum Hauptinhalt wechseln
ASUS PadFone X Station USB Charging Port Replacement
Was du brauchst
  1. ASUS PadFone X Station USB Charging Port Replacement, Back Cover: Schritt 1, Bild 1 von 2 ASUS PadFone X Station USB Charging Port Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Using the plastic opening tools, insert it into the edge and pry open.
    • Use hands to help pull the back off from the front if needed.
  2. ASUS PadFone X Station USB Charging Port Replacement, Check USB Charging Port for water damage: Schritt 2, Bild 1 von 2 ASUS PadFone X Station USB Charging Port Replacement, Check USB Charging Port for water damage: Schritt 2, Bild 2 von 2
    • Locate CON2002
    • Check water indicator on USB Charging Port
    • A white indicator means there is no water damage. A red indicator means there was water damage.
  3. ASUS PadFone X Station USB Charging Port Replacement, Removing Charging Port: Schritt 3, Bild 1 von 1
    • Locate and remove three Phillips screws
  4. ASUS PadFone X Station USB Charging Port Replacement, Disconnect E893821: Schritt 4, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use a pair of tweezers to disconnect E893821
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Daniel
338 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 7-4, Leahy Fall 2014 Mitglied von USF Tampa, Team 7-4, Leahy Fall 2014
USFT-LEAHY-F14S7G4
4 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
Does anyone have any idea where a replacement USB port can be found. Mine isnt water damaged but rather one of the pins broke off and its hanging out of the cable. Now the phone will not charge.
rich - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 2,700
