Einleitung
Is your device selfie camera failing to take photos? Probably it is time to get a new front camera. Use this manual to replace the front camera lens assembly.
Was du brauchst
Insert the plastic opening tool between the edge of the screen and the back cover.
Gently pry them apart. Use hands to pull them apart if necessary.
Use a Phillips #00 screwdriver to remove the three 2.5mm screws that secure the speaker case to the motherboard.
Use tweezers to remove cover sticker on the dock station.
Use a Phillips #000 screwdriver to remove the six 0.6mm screws that secure the dock station case to the motherboard.
Flip the device upwards.
Gently push the right side of motherboard down away from the dock station.
Ein Kommentar
I can not get my back off the device at the top of it it doesn't want to complete separate.
