Einleitung
This guide will be helpful for repairing the speaker if the troubleshooting page recommends that you replace it. This is a necessary step when you have determined no other way to repair your current speaker.
Was du brauchst
Insert the plastic opening tool between the edge of the screen and the back cover.
Gently pry them apart. Use hands to pull them apart if necessary.
Remove the three pieces of tape that secure the battery and its wires. Peel gently so you don’t damage any wires.
Disconnect the ribbon from the motherboard by gently pulling with your fingers.
Using the opening tools, pry the battery off of the adhesive.
Use a Phillips #00 screwdriver to remove the three 2.5mm screws that secure the speaker case to the motherboard.
Use tweezers to remove the three pieces of tape that are covering the metal.
Insert the metal spudger beneath the speaker case and wedge it upwards to remove speaker case from the device body.
