Zum Hauptinhalt wechseln
ASUS Portable AiO PT2001 Back Panel Replacement
Was du brauchst
  1. ASUS Portable AiO PT2001 Back Panel Replacement, Back Panel: Schritt 1, Bild 1 von 3 ASUS Portable AiO PT2001 Back Panel Replacement, Back Panel: Schritt 1, Bild 2 von 3 ASUS Portable AiO PT2001 Back Panel Replacement, Back Panel: Schritt 1, Bild 3 von 3
    • Remove the grey scuff guard at the bottom of the PC by pressing down on it, and pulling it away.
    • Lift the hinge and remove the grey rubber tabs on either side of the PC’s model information.
    • Remove the two 7.62mm Phillips #1 screws beneath the rubber tabs under the hinge and the four 7.62mm Phillips #1 screws where the scuff guard was removed.
    • Remove the two 4.74mm Phillips #1 screws under the hinge (near the hinge joints) and a 4.74mm Phillips #1 screw under the handle.
  2. ASUS Portable AiO PT2001 Back Panel Replacement: Schritt 2, Bild 1 von 3 ASUS Portable AiO PT2001 Back Panel Replacement: Schritt 2, Bild 2 von 3 ASUS Portable AiO PT2001 Back Panel Replacement: Schritt 2, Bild 3 von 3
    • Use 1-2 plastic opening tools or nylon spudgers to firmly pry open the back panel.
    • We recommend that you start prying the panel where the scuff guard was removed.
    • Prying the back panel will cause loud popping noises. This is just the sound of the clips that hold the back panel to the PC popping off.
    • Using excess force while prying can break the clips that hold the back panel and can damage the ports on the side of the PC.
  3. ASUS Portable AiO PT2001 Back Panel Replacement: Schritt 3, Bild 1 von 3 ASUS Portable AiO PT2001 Back Panel Replacement: Schritt 3, Bild 2 von 3 ASUS Portable AiO PT2001 Back Panel Replacement: Schritt 3, Bild 3 von 3
    • Disconnect the three cables connecting the back panel ports to the motherboard.
    • Flip up the locking latch holding the two ribbon cables with a plastic opening tool and pull the cables out.
    • Gently wiggle the third connector out of its socket.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team S17-G5, Livingston Spring 2018 Mitglied von Cal Poly, Team S17-G5, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G5
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 14
Insgesamt: 1,185
