Zum Hauptinhalt wechseln
Einleitung
We will replace the hard drive in this guide. The only necessary tools are a screwdriver and a spudger/plastic opening tool.
  1. Remove the grey scuff guard at the bottom of the PC by pressing down on it, and pulling it away. Lift the hinge and remove the grey rubber tabs on either side of the PC’s model information. Remove the two 7.62mm Phillips #1 screws beneath the rubber tabs under the hinge and the four 7.62mm Phillips #1 screws where the scuff guard was removed.
    • Remove the grey scuff guard at the bottom of the PC by pressing down on it, and pulling it away.
    • Lift the hinge and remove the grey rubber tabs on either side of the PC’s model information.
    • Remove the two 7.62mm Phillips #1 screws beneath the rubber tabs under the hinge and the four 7.62mm Phillips #1 screws where the scuff guard was removed.
    • Remove the two 4.74mm Phillips #1 screws under the hinge (near the hinge joints) and a 4.74mm Phillips #1 screw under the handle.
  2. Use 1-2 plastic opening tools or nylon spudgers to firmly pry open the back panel. We recommend that you start prying the panel where the scuff guard was removed. Prying the back panel will cause loud popping noises. This is just the sound of the clips that hold the back panel to the PC popping off.
    • Use 1-2 plastic opening tools or nylon spudgers to firmly pry open the back panel.
    • We recommend that you start prying the panel where the scuff guard was removed.
    • Prying the back panel will cause loud popping noises. This is just the sound of the clips that hold the back panel to the PC popping off.
    • Using excess force while prying can break the clips that hold the back panel and can damage the ports on the side of the PC.
  3. Disconnect the three cables connecting the back panel ports to the motherboard. Flip up the locking latch holding the two ribbon cables with a plastic opening tool and pull the cables out. Gently wiggle the third connector out of its socket.
    • Disconnect the three cables connecting the back panel ports to the motherboard.
    • Flip up the locking latch holding the two ribbon cables with a plastic opening tool and pull the cables out.
    • Gently wiggle the third connector out of its socket.
  4. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  5. Remove the four 5.0 mm Phillips #1 screws on the outer casing of the hard drive.
    • Remove the four 5.0 mm Phillips #1 screws on the outer casing of the hard drive.
  6. Gently pull the hard drive away to disconnect it from the motherboard. Gently pull the hard drive away to disconnect it from the motherboard.
    • Gently pull the hard drive away to disconnect it from the motherboard.
  7. Remove the four 3.5 mm Phillips #1 screws on the edges of the outer casing, two on each side.
    • Remove the four 3.5 mm Phillips #1 screws on the edges of the outer casing, two on each side.
  8. Separate the hard drive from the casing.
    • Separate the hard drive from the casing.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Runjia Chen
256 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S17-G5, Livingston Spring 2018 Mitglied von Cal Poly, Team S17-G5, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G5
4 Mitglieder
8 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 2
Letzte 7 Tage: 20
Letzte 30 Tage: 69
Insgesamt: 482
